#284128 - 05/06/02 05:37 AM Tire pressure help
N8sX Offline
Loc: Salt Lake City, Utah
No one I mean no one has a clue what pressure I should be running in my BFG TA/KO's the dealer inflated these bad boys up to 45PSI when I took it in last week for an oil change. It states on the sidewall the 65PSI is max, but what is good? My tire size is the stock 265/70R16. Please let me know. I called BFG and the recommended going with the manufactures door sticker which is 30PSI, is that enough?
Nate
#284129 - 05/06/02 06:23 AM Re: Tire pressure help
RS Offline
Loc: Lincoln, RI
>>No one I mean no one has a clue what pressure I should be running in my BFG TA/KO's ... I called BFG and the recommended going with the manufactures door sticker which is 30PSI, is that enough?<<
Assuming you're talking about road use, it sounds like the tire manufacturer has a clue. It isn't rocket science. Try 30psi and see how it looks and feels. FWIW, my stock grabbers were at 45 when I got my X from the dealer. The road ride was much more civilized when I brought them to 30.
Roger
#284130 - 05/06/02 06:25 AM Re: Tire pressure help
Olegkha Offline
Loc: Brooklyn, NY
the sticker on the door days 26
run them anywhere between 28 and 35, and you will be ok
#284131 - 05/06/02 10:37 AM Re: Tire pressure help
How completely unscientific of you.
#284132 - 05/06/02 11:00 AM Re: Tire pressure help
Olegkha Offline
Loc: Brooklyn, NY
[b]the sticker on the door days 26
How completely unscientific of you.[/b]
What the hell are you saying ?!
do you have a problem with my answer?!
#284133 - 05/06/02 11:03 AM Re: Tire pressure help
Yes, 28-35 is a very big range for that tire.
Something a little more accurate, based on the weight of the vehicle, and the rated load limit of the tire would have been much better.
#284134 - 05/06/02 11:36 AM Re: Tire pressure help
Olegkha Offline
Loc: Brooklyn, NY
[b]do you have a problem with my answer?!
Something a little more accurate, based on the weight of the vehicle, and the rated load limit of the tire would have been much better.[/b]
Oh Ye ?
And What is the right number ?
running 26 or 28 ( what ever it is on the door, i dont remember ) makes tires look like they are underinflated
running 38 and up will feel very rough
so my GUES is a little over 28
a little under 35
