#284389 - 07/03/01 11:06 PM Front tire offset
dborden0 Offline
Loc: albany, or, usa
I recently put on some BFG All terrains on my Xterra, and I noticed when I was doing a little trimming that my front right tire sits back about an inch from my front left tire. On the left side I didn't have to hardly take anything off at all, and the right side I had to take off quite a bit. Has anybody had any experiences like this, and is this bad? It seems like the tires would wear unevenly? Any suggestions? Thanks.
#284390 - 08/03/01 06:10 AM Re: Front tire offset
blenderhead Offline
Loc: Grovetown, GA, USA
Have you check your measurment for ground clearance on both sides? It could be a matter of just adjusting your torsion bars. A number of people have had their X's sitting uneven and fixed it with a torsion bar adjust.
Blenderheads Xterra Homepage
Greg Moultrie
00 Aztec Red XE 3-pak
4x4 Auto
Greg Moultrie
4x4 Auto
#284391 - 08/03/01 10:05 AM Re: Front tire offset
Sits back an inch ?
Take it to the dealer, there should be no difference.
Regards,
Ian
#284392 - 08/03/01 05:55 PM Re: Front tire offset
I would definitely have that looked at!
XROCK
www.hxoc.net
Super Black Xterra-
The Peoples Champion
#284393 - 08/03/01 08:16 PM Re: Front tire offset
gearhead1972 Offline
Loc: Brewster NY
I too Had to trip more off of the Pass side then the drivers side I just thought it was from A very minor love tap I was in??
Kevin
00' Super Black SE 5 speed
31" BFG M/T's, ARB, Rancho RSX's
superblackxterra.tripod.com
Kevin
www.rockclmr.com
#284394 - 09/03/01 06:41 PM Re: Front tire offset
If you drive straight as you can so as to have both front tires come to rest on a perpendicular line/parking block, etc...
Do they reach it at the same time?
Maybe the body is off, not the wheels?
Just worth checking while you are at it.
Good Luck!
2001 Xterra SE 5 Speed Gold Rush
