1 registered (Tom),
46
#288504 - 11/07/02 06:05 AM
Re: Intermittent rear wiper
Loc: Atlanta, GA
is there a way someone could get their hands on the '02 rear wiper motor assembly (shop, etc) and just bench test it on that before tearing apart the rear hatch of your X?
dm
"Eat a live toad the first thing in the morning and nothing worse will happen to you the rest of the day." Got a question? You used to be able to ask Brent , but not anymore...
#288505 - 11/07/02 07:41 AM
Loc: South Carolina
electroken,
ah.. i get it now..that makes sense and seems like the easiest way to do it. let me know what you come up with and maybe i can convince my wife (we all have to answer to someone) to let me install it. thanks.
#288506 - 11/07/02 09:19 AM
Loc: Shelton, CT
Originally posted by Dariush Molavi: is there a way someone could get their hands on the '02 rear wiper motor assembly (shop, etc) and just bench test it on that before tearing apart the rear hatch of your X?
dm The device will attach to the wiring harness under the dash. There will be 3 connections: 1) power 2) ground 3) a connection to the blue/yellow wire on the rear wiper switch. This all assumes that the 2002 rear wiper switch is the same as in my 2000. If it isn't, someone should let me know soon.
#288507 - 11/07/02 12:58 PM
Loc: Ontario, Canada
Just for your information....
I used to have a '98 Pathfinder, before I switched to my X.
In the Path, they had a three way (off, int, and full on) If there is some way of taking that switch, and using the delay realy or motor from the Path and hooking it up to the X...
I'd be all over that!!
- Nik
Always be more curious than afraid.
#288508 - 11/07/02 08:57 PM
Loc: South Carolina
electroken, well... i went under there and tried to take a picture but it looks like hell. you can still go see it if you want: http://home.sc.rr.com/mroberts/wiper.jpg It isn't worth putting inline and wasting everyones bandwidth. the bottom line is that there appeared to be 3 wires into the top of the switch and three to the bottom. there was a pink one. a blue one with a reddish line down it and a black one (that i think had white polkadots but it is late and i could just be seeing things in the dark) i hope this garbled bunch of info helps some.
#288509 - 16/07/02 07:54 AM
Loc: Summerville SC
Went to the dealer today..was told instruction manual and window sticker is a miss-print No intermittent option on the 2002 model..ElectroKen, help!!
I'm a HEATHEN!?
#288511 - 16/07/02 11:08 AM
Loc: Summerville SC
Originally posted by ElectroKen: I have several versions of the circuit drawn up. The versions differ only in the way that the operator contols the delay. Which should I make first?
1) A fixed delay with only a small switch to activate or deactivate the circuit. The delay interval would be set by the installer at the time the box was installed. The 2000 X has a fixed delay.
2) A variable delay with a single knob to both turn the unit on and set the delay (like the volume control on an old car radio).
3) A variable delay with a small switch to activate/deactivate the unit and a separate knob to control the delay. This allows the delay setting to remain set when turning it on or off. It will also look more cluttered.
It would also be a plus if anyone can get me a 2002 wiring diagram for the rear wiper circuit. Without it I have to make some assumptions that may be wrong. I would opt for option 1, all I'm looking for is a sweep about every 10 seconds. I would not even want a continuous motion at all. As far as the diagram..I will do a little hunting
I'm a HEATHEN!?
#288512 - 16/07/02 11:52 AM
Loc: Atlanta, GA
ditto, a 10 second sweep would be nice.
#288513 - 17/07/02 06:22 PM
Loc: FlaVAtown
I'll double check my '02 X. I could swear mine is intermitent, but maybe I'm not remembering correctly.
I know for a fact that it does have a delay. I got mine back in August of last year. Wonder if they made some changes in the units they produced this year?
I'll post my findings.
/;0\
How do you know where I'm at when you haven't been where I've been, understand where I'm coming from?
#288514 - 17/07/02 07:23 PM
Loc: Medina, OH
Its good to know I am not the only one who hates the constant wiping. I always just turn it on for one wipe when i need it, becuase the constant wiping drives me crazy, and I have never been in weather that requires constant wiping. Its my only fault with the X. You could easily put a delay switch on the power wire, I am just not sure if that would be good for the wiper's motor. Well I guess I will just keep flipping the switch on and off.
#288515 - 17/07/02 08:05 PM
Loc: Franklin Park, NJ
Why would putting a delay-relay be bad for the motor? It's seems as though it would be the same as you clicking the switch on and off manually. I'll try to locate such a relay. Question is, what is the amperage going to the motor?
-Bryan
#288518 - 18/07/02 10:24 PM
Loc: New Zealand
You mean the '555 is dead?
-Paul 2007 Nissan X-Trail New Zealand (ex San Diego)
#288520 - 23/07/02 10:16 AM
Loc: Atlanta, GA
how's this gizmo coming along?
#288522 - 23/07/02 06:23 PM
If it works, will it be mass marketed?
-Bryan
#288524 - 24/07/02 02:12 AM
Loc: Dammit! Even CLOSER to Smith a...
Electroken strikes again! Dude, you ARE the man.
Sven, let's dig into yer truck over a couple beers, maybe next weekend?
This is how you post whore..
#288525 - 24/07/02 05:26 AM
Loc: Summerville SC
Originally posted by TatsuoX: Electroken strikes again! Dude, you [b]ARE the man.
Sven, let's dig into yer truck over a couple beers, maybe next weekend?[/b] I could do that, first I should contact Electroken and see how this item will get to my house... Edited to add, sent PM to Electroken. Tats I'm guessing you and I will be doing a little electrical work 3 or 4 August BBQ again?
I'm a HEATHEN!?
#288526 - 24/07/02 11:25 PM
The 4th sounds excellent to me!(I'll definitely get that day off.)
BBQ also sounds excellent again! More chowpau(sp)? :p
#288527 - 26/07/02 07:44 AM
Loc: FlaVAtown
Originally posted by lboogie: I'll double check my '02 X. I could swear mine is intermitent, but maybe I'm not remembering correctly.
I'll post my findings. OK so it rained today. I turned on the rear wiper and sure enough a 10 second delay between wipes. For me that's intermitent, I'm happy with it.
/;0\
#288528 - 30/07/02 02:12 PM
Loc: Summerville SC
Just wanted to say I received the delay today, ElectroKen is the man. Install looks simple, Tats and I should get this done easy this Sunday. Update on Monday...
Would like to add that this little black box looks extreemly professional...Some high quality stuff.
I'm a HEATHEN!?
