Can't help you on the brand, I got an
Eliminator which is sold only by Canadian Tire which is not available in the states. I only got a 200W and it works fine for what you want, but it only has one outlet.
The thing you need to know before deciding which model to choose is how much power your laptop and camera charger consume. Then decide if you want to be able to run them at the same time or not. Once you know how much you will consume, you can decide which size inverter to get.
If you go with more than 400W AND draw more than 400W from it, there is a strong chance you will blow a fuse. The rear outlet has a 20A fuse so that is about 240W (12V X 20A). That is why the larger inverters have posts so that you can hard wire it directly to the battery with the right gauge wire and an inline fuse.
Plugging a high wattage inverter in a 20A rated outlet will not blow the fuse on it's own, it all depends on how much power will be drawn from it.
Since they go up in price along with the wattage, there is really no point to buy bigger than what you will need unless you anticipate a larger consumption in the future.
Some of the larger ones in the 3000W and 4000W range are more meant to be used with a battery bank for example in a RV or house where you use house power, a generator or alternative energy to charge the batteries. Then you will be able to run larger appliances or tools when no other power is available.
ETA: Also, power inverters need power to power themselves, the larger the inverter, the more power it will need, so that is something to consider if you plan to run it when the engine is not running as a larger inverter will draw more from your battery.
If you google you will find several articles on how to select one.
http://www.google.com/search?q=choosing+an+inverter
