Well, here is the situation. I just ordered my cobra 75 (to replace my radio shack cb) and a firestik II two foot antenna. My current two foot antenna is mounted on my roof rack with an easyover.
The problem I am having is that I was never able to get a good ground on my current setup and signals were very weak. I could never tune the swr because of the grounding problems.
So, I know there are other threads on this, but they are kind of old. I would like to know if anyone has found a good method for grounding their antenna's. I have considered running a good thick wire from my mount directly to the chasis, but have heard that the ground wire shouldn't be too long or it will not work well. Another option I have considered is mounting my antenna on my ARB. But then I sacrafice a certain amount of range do to the antenna not being above the roofline. Also I haven't seen any pictures on anyone doing this yet and am kind of wondering how it would look.
So if any of you have any suggestions for me, I'm all ears. If you have any pics of your setup, that would be great too. Thanks for the help on this.
Also, I know many of you have allready installed the cobra cb in your X's. Where is a good spot to mount the box portion? Thanks again.
Sgt_Lobo
2000 4X4, SE, White
http://www.cableone.net/sgtlobo/xterra.htm
