1 registered (Tom),
46
Spiders online.
Key:Admin,
#293580 - 07/07/0611:02 PMTrailer wiring question
Ok I have searched the topics but cant find anything similar to the problem I am having hopefully someone can help me. I have a double pwc trailer that I smashed the right tail light off of due to m expert backing skills. after I hooked up the new light it doesn't work when brakes are pressed or turn signal is activated. The left side works fine along with running lights. At first I figured it wasn't grounded properly but when I turn on the headlights it lights up but turn and brake don't work. I hooked up another trailer and it has the same problem which leads me to believe that its the wiring in the xterra. So here's my question, Is there a separate fuse for just the right brake and turn signal in the trailer harness that might have blown? or something more serious?
Its not the trailer I tested the 7 pin receiver on the x and its not getting power to the right turn signal. The left turn signal works fine. Can anyone help me?
