Originally posted by bpdA:
Do you have the sheets for how to get to the factory head unit as well? I took a look at the setup for removing the titanium trim and it seems like there are two screws to undo but then it still feels pretty well tied down so I don't know if there is more to undo. Thanks!
On the 2002 you have to pull up the trim around the gear shift and transfer case levers. Just pull it straight up, it's a friction fit piece. Under there you'll find 2 screws to go with the 2 you probably found just below the AC controls. Lastly, you will have to disconnet the harnesses for the hazard lights and cigarrete lighter.
