The instructions that came with my Hella 500s are not very detailed, so I have a few questions.
How do I connect to the headlight wire? is that what the 2-slotted snap connector is for? I see three wires coming from the headlights: black red and red w/ green stripe. Which one is the high beam wire. Is there a wire I can tap so I can turn on the lights whenever my headlights are on, high or low beams? I don't want to connect them to a wire that is hot all the time.
Is there a best/easiest place to: mount the relay, attach grounds for lights, relay, switch?
I'm going to put the switch in the blank on the driver's side. What is the easiest way to run the wires to the switch? I did a search on all of this and found the ways to get through the firewall. Is one really easier than the other?
Sorry for all the questions, but I hate wiring stuff. Anyone in Austin want to come help? wink
'01 Gold Rush, 3-Pak, 4X4, 5 speed
