1 registered (Tom),
67
#388543 - 31/01/08 11:15 PM
Re: TJ
I'd give the Whoo Haa guy a try. You have some drilling...but the bone looks strong....and its cheaper than most (all?) of the others.
#388544 - 01/02/08 03:40 AM
Re: TJ
Loc: Exton, PA
Whoo Haa guy ??? WHO IS THAT
#388545 - 01/02/08 05:43 AM
Re: TJ
I think he means Hoo Haa or whatever it's called..
#388547 - 01/02/08 11:26 AM
Re: TJ
HooHaa center link is $225 plus $100 core fee. http://www.xterraownersclub.com/cgi-local/ultimatebb.cgi?ubb=get_topic;f=60;t=000386
#388549 - 03/02/08 08:14 AM
Re: TJ
Well, if you don't mind the extra $, and you still have core sharges until you get your core back to them, (Same as the other...), L&P's system is also very good....and more complete. Go with the Stage III and what ever upgrades you can, so you can call it once and done then....and be done with it. Are you sure about your steering pump? I ask, because a LOT of them just needed a little adjustment screw attention to work well again, etc. A lot also leaked a bit here and there...but just adding new fluid was sufficient to let them ride, etc. Mine was leaking a smidgen here and there, I flushed it and replaced the fluid with synthetic, and it was fine after that. Food for thought.
#388550 - 03/02/08 07:30 PM
Re: TJ
Loc: Oak Ridge, NJ
Originally posted by k_enn:
Should I also get heavier tie rod adjusters while I am at it? FYI: If you decide to upgrade the tie rod adjusters I have a few pair of EOE HD adjusters still left.
