12/04/18 11:46 AM
0 registered (), 65 Guests and 1 Spider online.
#395783 - 11/03/08 06:45 PM 2006 XOR Rancho Quicklift & Shrock Front Bumper
Hello,
Just curious what everyone's thoughts are on this project? I would like to install the quicklift and tires as well as the shrockworks front/rear bumpers. My question to anyone with an educated opion is this...other than the quicklift kit, would I have to undertake any other mods upfront due to the added weight of the front bumper? It states in the article that it sits perfectly level. I would like to retain that look with the shrock bumper installed. I am a newbie to mods so please go easy. Your help is greatly appreciated.
p.s.
here is the article referenced.
http://www.4wdandsportutility.com/tech/0702_4wd_2006_nissan_xterra_suspension_ upgrade/index.html
v1
#395784 - 11/03/08 07:18 PM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
I went local (DunBar Spring) phx,AZ
and made mine to my likings.they will ask a couple of questions on towing and daily driver and offroad ect ect. it rocks!i saved $$ and got more from buying local.hope this helps.O and the wait time was about a day if the work is done in house laugh
#395785 - 11/03/08 09:45 PM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
Thanks for the reply. I am trying to figure out if I will need to add any thing else to level the front end, post-quicklift? I am moving to Las Vegas in the next month or two and was going to have it done out there. I don't want anything more than what you see in the pics in the article. The 285s and the front bump and sliders. How much did it run ya btw? Thanks again!
#395786 - 12/03/08 07:35 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
Admittedly, I don't know anything about the Rancho lift for 2nd gens, but the Rancho lift for the first generation Xterra wasn't worth the steel it was made from, so I'd be wary of using the kit for the 2nd gens.
#395787 - 12/03/08 08:14 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
Thanks... what would you suggest to get the desired look and functionality. I would estimate that 75% will be on-road as this is my daily driver. I am not going to go rock crawling or anything like that. Primarily taking it on trails to go camping, hiking, biking etc. I want to put 285/75/16s on it and give it a lil better stance. will the 285s rub or bind without a lift?
#395788 - 12/03/08 08:43 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
i am running the Daystar 2.5 lift with the custom rear leaf-pac 4.5 with oversize rear Rancho 9000 adjustable shocks front and rear can cruz like a caddy or full bore offroad .its pimp
Onix laugh
#395789 - 12/03/08 08:51 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
righton... how much did that set you back for parts if you don't mind my asking? I am going to get a local shop to do mine. Anyone in the Vegas area have any recs?
#395790 - 12/03/08 09:07 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
daystar 200.+ give or take and rancho.com check with a local shop who sells them or go direct tennaco/rancho syspention. you will need to do rear leaf pac with the shrock bumper as for the fron i dont need that much wait on the front end so i plan on building a prerunner bumper. running stock bumper for now.hope this helps
Onix [Smoking]
#395791 - 12/03/08 09:22 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
onix. that helps! any info is appreciated as i am new to all of this. How's the valley treating ya? I moved out of there back in 01 and now moving to vegas in may. damn i picked a great time to move, should have waited til the winter!
#395792 - 12/03/08 09:29 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
Not bad im in Scottsdale.Its like there is more traffic every year go figure. laugh
#395793 - 12/03/08 09:37 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
If you come threw AZ look us up arizonaxterraclub.com we could do some wheeling or other club stuff.Onix
#395794 - 12/03/08 10:04 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
Ah, www.azxterraclub.com Wally. wink
#395795 - 12/03/08 10:08 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
sounds like a plan! my schedule is 8days on/7off so i could make my way down there to visit friends!
#395796 - 16/03/08 10:32 PM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
I have not heard good things about the Rancho quick lift for the 2005+. IMHO, if you are adding a Shrock front bumper, you should upgrade your front coil springs - instead of using a spacer.
#395797 - 17/03/08 07:12 AM Re: 2006 XOR Rancho Quicklift & Shrock Front Bumper
That is good to know about the Rancho Quicklift setup. I would just like a lil better and more aggressive stance on mine. If you took a glance at the rancho article, the pics in there are what i am going for.
