#427849 - 22/05/07 09:19 AM question about shocks
Does anyone know if you can use these shocks for the calmini 5" or 3" lift. They are 3" longer then the stock socks at the lowest setting, and can be adjusted to fit with the 5" lift without the need for spacers. I just want to know if it will work.
http://www.4wheelparts.com/PDT52778.aspx
#427850 - 23/05/07 01:56 PM Re: question about shocks
to answer my own question, they will fit. I decided to try yesterday and they went right in.
#427851 - 26/05/07 11:47 PM Re: question about shocks
Dude if you wanted some bad ass shocks to go along with the calmini 5" lift. You should have called Greg over at PRG. I am currently installing the calmini lift and i bought a coilover from Greg that can be adjusted from 4-7" larger than factory. I think the cost was 750 for the pair. when i get everything installed i will snap some pics.
#427852 - 28/05/07 08:00 PM Re: question about shocks
So, you figured it out already.. New nissan shocks delivered yesterday which is made for my rig, the amount of lift doesn't really matter.
#427853 - 31/05/07 12:14 PM Re: question about shocks
I don't see how those shocks would fit in your OEM shock mounts. confused
