Yesterday at 04:27 PM
#429623 - 19/05/01 07:37 PM alignment
rjm022 Offline
Loc: york
went and had my tires balanced and rotated. after i left, i noticed my truck pulling to the right.i thought it was just the crown of the road. but i noticed when i got home, there was two balancing weights on the driver side tire and only one on the passenger side tire. could that do it??
#429624 - 19/05/01 07:58 PM Re: alignment
PFord Offline
Loc: Tallahassee, FL, US
Nope, those few ounces will not shift weight balance enough to make a truck pull. Check your tire pressures with an accurate gauge. If you find them to be equal or very near equal (1-3 pounds) then I'd go to an alignment shop and get that sorted out.
-P
1991 Range Rover
1986 BMW 325
Potential Unimog owner
1991 Range Rover
1986 BMW 325
#429625 - 19/05/01 10:01 PM Re: alignment
rjm022 Offline
Loc: york
thanks. your probably right! i just found it odd, that i noticed it after leaving the shop. going in for warranty work soon. i'll get an alginment when i am there.
#429626 - 19/05/01 10:38 PM Re: alignment
It's perfectly normal for different numbers of weights to be on each wheel, since each wheel/tire combo may be off independant of the other. Not only the number, but the size of the weights can vary. Sometimes 1 large weight will suffice, others may require 3 small weights scattered around the rim etc.
[This message has been edited by OffroadX (edited 05-19-2001).]
