17/04/24 01:48 PM
#430135 - 23/03/04 11:37 AM bumpstops
i did a search and couldnt find the answer...
if i am just installing the AAL's from calmini, do i need to install the bumpstop extentions?
i called them and they said i do, but i get the feeling they are being overly conservative.
i would think they would only be necessary if i had the shackles as well?
i know the advantages and disadvantages... but is it really likely that i would over extend the leafs without the shackles?
thanks
conor
#430136 - 23/03/04 11:53 AM Re: bumpstops
ChuckH Offline
I wouldn't install them with just the AAL's. If you do then you're going to be riding closer to your bumpstop than you are now and your articulation will suffer.
#430137 - 23/03/04 12:22 PM Re: bumpstops
Loop Choke Offline
Loc: Peoria,IL
I have shackles and AAL's and do not have my extensions installed. IMHO it is not needed.
Jason
So that one may walk in peace.....
#430138 - 23/03/04 01:02 PM Re: bumpstops
thanks for the input... i really didnt think they were necessary, but i wanted to see what you all were doing.
thanks for the ideas
conor
#430139 - 23/03/04 04:46 PM Re: bumpstops
Generally, bumpstops are more related to tire size...if the tire is a larger diameter, you extend the bumpstop to keep it from hitting on the way up...
