17/04/24 01:48 PM
0 registered (), 35 Guests and 0 Spiders online.
#431330 - 13/08/01 02:58 PM 2" suspension lifts?
Mel A. Offline
Loc: Texas
Are there any 2" suspension lifts available for the Xterra? I have only seen 3" lifts available. Would I have to buy new extended driveshafts for a lift? What is a good tire-size to fit on a 2" lifted Xterra, I don't want to lose that much power and I don't want to spend the xtra $$$ on new gearing? thanks.
Mel A.
1995 Land Rover Discovery
looking into an Xterra XE 4x4
#431331 - 13/08/01 03:06 PM Re: 2" suspension lifts?
stormy Offline
Loc: NH
Rear shackles are about 2" ($50 at SLR). If you give the torsion bar adjusting bolts a few turns should get you up in the front (up to you how much but I wouldn't go too high without high angle a-arms).
A very inexpensive 2" lift. You may need an allignment after you do it.
I sure if you search, you will find more than enough info on this. wink
#431332 - 14/08/01 04:38 AM Re: 2" suspension lifts?
FSRBIKER Offline
Loc: Oak Ridge, NJ
Go with rear add a leafs than longer shackles, the add aleafs will not only raise the back end of your truck...they will make the ride better, handle a bit more payload without sagging and extend the life of your springpack...all for about the same cost as the shackles. You do need to run longer shocks but for the shackles you do as well.
FSRBIKER
97 TJ, 2" lift, 32's
EOE...Opening Soon!
#431333 - 14/08/01 06:29 AM Re: 2" suspension lifts?
wqbang Offline
Loc: Auburn, WA
BTW, 32X10.50X15's will fit on a stock Xterra with a little mudflap trimming and torsion adjustment
Tread Lightly!
#431334 - 14/08/01 08:25 AM Re: 2" suspension lifts?
Mel A. Offline
Loc: Texas
ok, If I raise the truck 2" without extending my shocks wouldn't I lose 2" of down traval and gain 2" of up-travel? Where is a good place to get longer shocks? Also, for the front torsion bars, couldn't I just buy some already made for the lift? Because if I do the bolt thing, the torsion bar would lose some of their strength,right? Are there any companies that make a coil spring conversion to replace the leaf-springs? thanks.
#431335 - 24/08/01 08:10 AM Re: 2" suspension lifts?
stormy Offline
Loc: NH
Click on the banner ad on the top of the page... you can buy longer shocks, t-bars, aal's there.
