0 registered (), 51 Guests and 0 Spiders online.
#433173 - 07/04/06 01:28 PM Calmini steering prob
Trying to install my calmini steering and have run into a problem.
driver side tie rod adjuster has bottomed out on tie rods. There is no more room to adjust, any advice, i did call calmini and they havent called back.
#433174 - 07/04/06 06:12 PM Re: Calmini steering prob
Could you be more specific?
Are both sides bottomed out of the driver side tie rod? Have you checked your center link to make sure it is the correct length?
What does your passenger side tie rod look like?
#433175 - 07/04/06 06:46 PM Re: Calmini steering prob
ok well, the top nut is all the way down. And the centerlink measures from each zurk fitting, 31 1/2. i think i figured it out, we will see tom.
