I just had the Calmini AAL’s and shackles installed. Had a few questions.
·The bump stop extensions are they suppose to be flush with the frame of the body? There are two holes for the bolt and nut. Do the extensions come in the blue color? Is the bolt threads suppose to be that long?
·The rear sway links are the installed properly? The bolt threads are pointing outwards is this right? Can I flip the direction of the threads and shaved them down? It should be installed like the stock, from top to bottom, frame to link and link to bar. right?
·AAL holders, I only have one per side, away from the shackles? Shouldn’t I have two to a side? They don’t seem to hold them since the 2 AAL’s can I purchase some bigger ones?
·The bolt and nut away from the shackles is nut suppose to be on the outside or inside?
·On my shackles, I want to have the Calmini logo facing the outside. On one side they are facing the same direction, do I just flip them? Do I just following the crease?
