I would reindex what you have and see if that works first....that won't cost you a dime and it'll take about an hour.
If you haven't removed a Tbar before, it's not too bad....clean everything up real good first and hit the Tbar anchor bolts front and rear, as well as the Tbar splines with plenty of penetrating oil for a couple days before to make it easier.
On the passenger side, mark the splines and the anchors both front and rear with a paint pen so you know exactly where it was before, and rotate the bar 2 splines counterclockwise looking toward the front of the truck and reassemble.
Then, when you're adjusting, measure to the top of the fender opening using the hub as a centerline. Drive the truck around the block a couple times and readjust, as it will settle a little bit after reinstallation.
