#463322 - 11/12/0512:13 PMClunk/ Bang after driving
After starting the X and driving a few feet i hear a bang from the underside. sonds like something is hitting the exhaust or something is loose in the suspension. it is usally worse while turning. usually only happens once
i also have another concern that the oil pressure gauge fluctuates alot on this thing after it warms up. it usually drops down at idle and when i use something electrical like turning on the headlights. i realize oil pressure gauges are supposed to fluctuate but this seems like more than most other engines
#463323 - 11/12/0512:16 PMRe: Clunk/ Bang after driving
are you in 4x4 when this noise happens???
The oil pressure thing is normal. Though I think it may be your imagination that it changes based on electrical accessories. It should move dependant on rpm only.
#463324 - 11/12/0512:32 PMRe: Clunk/ Bang after driving
2wd
im not imagining it believe it or not. sitting at hot idle turning the headlights on or off makes the pressure guage fluctuate for a second, but it returns to normal
