Hi every one, im new here.
I have an 03 Supercharged xterra 4wd. And im due for my first set of tires.
I been reading through alot of posts but couldnt find anything on this model.
I have some questions , hopefully someone can help.
Money IS partial issue, and also work involved doing a lift. So, here are my questions
Keep in mind this is for the Supercharged version which has different rims then regular x's
1- I will keep my stock Supercharged rims, is so what is the biggest tire i can fit?
2- If i go with just a SL ( the cheapest that wont require any modding) i think 2 or 3 inch lift? what will be my largest tire i can use now?
3- I really dont want to mod anything like shocks, or steering mechanisms, shifter, etc.. so what is the largest lift i can use before needing to do any of that? basically i want to go as high as i can, with the largest set of tires on my stock x supercharged rims WITHOUT having to mod anything. ( i noticed some people cut the moulding area near their front door.. that doesnt seem so bad so i can probably do that)
Right now i have factory 265/65/17
Thanks so much
