#499014 - 20/11/04 11:39 PM Tire rub
I posted this in the tire forum with no reply, so im trying a post here. does any one have a fix for the tire rubbing the brake sheild in the passenger side wheel well. It does it when turned all the way right. I have an 2002 with 265/75-16's and no lift.
And yes I tried the search
#499015 - 22/11/04 06:06 PM Re: Tire rub
OnlyOneDR Offline
You can either:
1. "Modify" the shield with a hammer or other favorite beating tool.
or
2. Adjust your rear steering stop on that side. There is a bolt with a metal/plastic cap on the lower rear of the knuckle that you can adjust a bit to prevent the tire from getting too close to the shield. Just loosen the jamb nut, unscrew it a bit, and tighten the jamb nut. Test and repeat if necessary.
Personally I like option #1. [Too much XOC]
http://www.noas4x4club.com/
#499016 - 23/11/04 08:21 AM Re: Tire rub
Easiest thing is take off the shield, bend the mounting tabs the same amount, to force the shield to sit a little farther back, and in towards the frame, then put it back on. Doesn't take much, and there's plenty of space to move it back almost a whole inch.
