#499248 - 05/12/06 06:55 PM Lesser money sas
Just thought i would share with you guys my final price on the sas.
Dana 44 gears plus install kit-187.14 (ebay)
superwinch manual locking hubs-45.34 (ebay)
Rear fox shocks(splurged a little here-310 (ebay)
35 inch bfg muds and rims- 250 (co4x4.org)
Coilovers with springs-460 (ebay)
Dana 44 rebuild kit-100 (ebay)
waggy axle and custom made square driveshaft-174 (pull and save)
Wheel spacers and leaf perches-50 (friend)
Random tools and autozone trips-250 (autozone)
Calmini SAS kit-1825.52 (picked up at Allphase Offroad)
Rear h233b gears-420 to my door (4x4parts.com)
so around $4350 all said and done
Of course it also nice to have a friend with every sort of tool possible and doing everything including gears urself. But with patience and time it can be done for fairly cheap allowing you to splurge on a few items.
Any questions just ask.
Max
#499249 - 05/12/06 07:04 PM Re: Lesser money sas
Kaiser Offline
Wow - you got some really great deals there! That's probably about as cheap as it can be done.
#499250 - 05/12/06 10:19 PM Re: Lesser money sas
thats awesome...got part #'s ?
#499251 - 05/12/06 11:07 PM Re: Lesser money sas
i got em off ebeay i dont know the part numbers...
#499252 - 06/12/06 12:09 AM Re: Lesser money sas
you used a Calmini kit but still had leaf perches made??
#499253 - 06/12/06 05:30 AM Re: Lesser money sas
Yes. The base Calmini kit is the front end minus the coilovers and driveshaft. For the rear end he hadta go SOA or buy lift leaf packs.
#499254 - 06/12/06 11:33 AM Re: Lesser money sas
thanks jeff you got my back...
max
#499255 - 06/12/06 11:56 AM Re: Lesser money sas
Mine was considerably less with leaves and I have an ARB front locker, diff armor, and a beefed pitman arm. That ride is nicer with the coilovers though. My rear axle was already geared with 5.14's when I had the IFS under it.
Custom spring hanger: $100
Custom shackles: $50
Rough Country 8044 springs (ebay) $190
Waggy D44 from a yard $235
All new steering links - Krage Motorsports - $200ish
Piece of tube to lengthing new waggy draglink; $1
Customized / gusseted pitman arm (I splurged here) $125
New Warn Premiums, 4 balljoints, Spicer 760X Ujoints: $110 from a guy on Pirate
2 cans of flat black spraypaint: $5
2 Ford F250 shock towers: $27
Brake lines and fittings: $70
Custom Driveshaft: $200
Ubolts and ubolt skids (things of beauty): $75
Misc bolts, hardware: $40
ARB Locker (used but reconditioned with new seals) $400
Precision 5.13 gears and install kit: $275
Rancho 5116 shocks: free (they were my old rear shocks)
Warn diff Skid: $60
Locker/gear install: $175
New Wheel bearings and seals: $60
Resurface Rotors: $15
Remanufactured Calipers: $22
New brake pads: $18
Misc grease, parts cleaner, penetrating oil, etc.: $15
New set of lugnuts $10
Total $2478
I'm not counting tires and wheels because I used the same 32's I had for a while before stepping up to 33's. Also, I already had a set of BDS rear springs and some crazy 7" shackles out back for height there (it sat tail high with IFS, now it sits a little nose high).
Add the rear gears and springs that were already on the truck and I'd still be in the neighborhood of $3500.
#499256 - 08/12/06 04:26 AM Re: Lesser money sas
Both sound like great deals with great end results.
You guys are both very resourceful!
[ThumbsUp] [drink]
Now it's my turn!!
I won't be able to match your price, though.
Stay tuned; I plan on being SASed within 45 days.
