It's so simple to re-configure the switches you can do it however you want.
- The harness has three plugs for switches, one for the pump, and two actuator plugs.
- As long as the pump is in an accessible place, it is soooooooooooo easy to add a solenoid to the pump at any time
- When you route the harness and place the switches, make sure you have enough room to hide the third plug for future rear locker use
- While using a single locker, make sure to use plug number 1 (unless you feel like farkin' with the harness to make sure switch number 2 will activate w/o activating switch 1)
