17/04/24 01:48 PM
#52288 - 17/05/05 01:31 AM help horn installation
hi, i just got my new supertone horn set
(hella).please anybody can give me how to replace my stock horn for 2004 xe.
#52289 - 17/05/05 06:31 AM Re: help horn installation
Ill post how I hooked up my Hella horns. I dont remember what website I found it on, but I kept a printout and that is in my X. So later today ill have it posted for you.
#52290 - 17/05/05 04:10 PM Re: help horn installation
This is how I have my horn set up.
Wire from the stock horn is connected to terminal #85 of the Hella relay coil
Ground terminal #86 of the coil
Run a fused wire from the battery to terminal #30
Take terminal #87 to the positive side of the horn
ground out the negative side of the horn.
I got this from coolerman a year or so back.
#52291 - 18/05/05 04:26 AM Re: help horn installation
Toy Man Offline
Loc: Beaverton Oregon
I think I just stuck my Hella's in place of the existing horn. Definitely did not use a seperate relay. I have had 2 sets of Hella's and a set Wolo's on the X using the same stock wiring. All have worked A-OK.
Toy Man
#52292 - 18/05/05 06:12 AM Re: help horn installation
I agree with the above post. I replaced my stock horn with the PIAA setup and I used stock wiring. Unplug, unbolt, (I had to build a simple bracket to mount both new horns) and then reinstall.
#52293 - 18/05/05 06:35 AM Re: help horn installation
I thought about that, I just didn't want to go and keep replacing fuses if it didn't work. : ) So I went with the safe option and used the relay. It is good to know that someone people didn't have problem just pluging it in and going.
#52294 - 18/05/05 12:12 PM Re: help horn installation
thanks, for all the info. acually yesterday after posting my problem, i tried to just use the stock wiring and ground them, and its working fine.
#52295 - 18/05/05 12:52 PM Re: help horn installation
xterraintx Offline
Loc: Eddy, TX..
I used a relay and replaced the broken stock horn too. So I have the air horns for traffic and still have the stock one for chirping when locking. Not enough juice to power the air horns for the chirp.
I know I don't need to hear the beep when locking but sometimes the door is still ajar and it does not set... I like to know that.
