you can always just get one from any regular parts place...autoZone, etc. and trim off the excess....viola!
Be careful with this idea unless you're looking at replacing the rubber blade refill insert only and not the entire wiper blade assembly. I always replace the blade and frame because it goes through a lot of abuse during our wisconsin winters.
You can do even better by going to a larger wiper blade. The stock 2nd Gen X rear wiper blade is 12 inches long. You can replace it with a 14 inch blade from the Murano.
It fits perfectly and clears more of the rear glass.
Yes, the Trico Exact Fit Rear Integral Blade comes in 12" and 14". I stick to the original size because I don't want to stress out my wiper motor, linkage or arm. As mentioned above, the wisconsin winters are brutal on wipers - especially rear wipers.
I've gotten OEM replacement blade that is exactly what Nissan uses for the Xterra. I got it online, think it was autowarehouse.com and if I remember correctly it was less than $20
Yes, the trico is an exact OEM replacement without having to deal with the dealership!! I think it was about $12.
