Not sure if that's what I would do. Here's why.
Assume normal air pressure of 35psi.
Gravel / Dirt: 25psi (total reduction of 29%)
Moab: 18psi (total reduction of 49%)
Snow: 10psi (total reduction of 71%)
Racing: 50psi (total increase of 43%)
NOTE: I would only run these pressures if using an aftermarket tire with superior sidewall reinforcing. The deflation may cause less clearance under diff, but this is not a big deal... dropping the air pressure will grant you traction that is more valuable than clearance issues (pick a better line!)
KE7AEY
