Yesterday at 04:27 PM
#573253 - 10/06/10 11:50 AM Airfoil/Wind Deflector seal broken and vibrating
Hrd2Imagin Offline
Loc: Pittsburgh, PA
I was packing up my roof rack for a camping trip when I apparently screwed up my airfoil (or wind deflector). As I started driving down the highway, I heard a terrible noise like someone was pounding on my roof.
As a quick fix, I ran some duct tape along the front so wind couldn't get up underneath it and that worked. I then removed the airfoil when I got home after my trip.
I don't recall if there was a seal between the airfoil and the roof and I may have broken it, or I had just bent it out of shape (I was putting fold up chairs underneath it at the time)
Is there a seal between the airfoil and the roof? Can it be re-sealed? If so, with what? Any slick aftermarket parts I can buy? Any suggestions would be great!
Thanks!
Alan
Hey I build websites!
#573254 - 10/06/10 12:07 PM Re: Airfoil/Wind Deflector seal broken and vibrating [Re: Hrd2Imagin]
There is a rubber seal on the airdam. Not sure that there is a replacement part or if you have to buy a new one.
Call Couresty Nissan and ask or check their site.
http://www.courtesyparts.com
Edited by XOC (10/06/10 12:07 PM)
#573255 - 10/06/10 12:09 PM Re: Airfoil/Wind Deflector seal broken and vibrating [Re: XOC]
looks like it is replaceable.. did a quick search on their site
http://www.courtesyparts.com/kb_search_result.php?keywords=[73163U]+\%28wd22&cPath=532_14_67_68
You will have to copy and paste to get the whole url
Edited by XOC (10/06/10 12:11 PM)
#573260 - 10/06/10 06:29 PM Re: Airfoil/Wind Deflector seal broken and vibrating [Re: XOC]
swampwrecker Offline
Loc: Brunswick, GA
Here's the seal that you need. It's really gone up in price. I bought one about 5 years ago and it was only $6.00. You should put a little silicone adhesive on it to keep it from flying off. Once it starts rattling, it usually doesn't stay on too much longer.
-Michael
Michael Girardo
East Coast Xterra Challenge
swampwrecker@ecxc.com
#573264 - 11/06/10 08:06 AM Re: Airfoil/Wind Deflector seal broken and vibrating [Re: swampwrecker]
e207 Offline
Loc: Ashland, PA U.S.A.
they arent actually "sealed" though, are they? the air foil is made to be removed when/if needed. Mine has a very thin foam rubber type thing stuck to the roof, but it doesnt stick to the foil.
2002 SE/SC R.I.P. March 2015
Bielstien's
Shrock Sliders
Captain 38-90
#573265 - 11/06/10 09:15 AM Re: Airfoil/Wind Deflector seal broken and vibrating [Re: e207]
slantyshanty Offline
Loc: Northern Michigan
Too bad you live on the other side of the terra, i have two whole air dams with the parts you need in my garage i could float your way.
#573274 - 11/06/10 01:53 PM Re: Airfoil/Wind Deflector seal broken and vibrating [Re: e207]
Loc: Brunswick, GA
The part I linked to is what gets attached to the bottom of the airdam, it keeps air from getting under the airdamn. What you are talking about is a thing strip of protective tape that protects the paint from getting scratched by the part I linked to.
-Michael
Michael Girardo
#573275 - 11/06/10 02:47 PM Re: Airfoil/Wind Deflector seal broken and vibrating [Re: swampwrecker]
e207 Offline
awwww, Ok, never took notice to the airdam having something else on it. , .. another day, another something learned !!!
Bielstien's
Shrock Sliders
Captain 38-90
#573282 - 12/06/10 05:08 AM Re: Airfoil/Wind Deflector seal broken and vibrating [Re: e207]
Loc: Brunswick, GA
I was thinking you also had a 2000. In 2002 they changed the airdam. I don't think you have the part that I linked to. Courtesy only lists that part for the 2000-2001, so your thinking for your truck was correct.
-Michael
Michael Girardo
