#59535 - 02/07/02 08:54 AM Rear-View Mirror/temp Question.
striker511 Offline
Loc: Cherry Hill, NJ
Hey Guys and gals [Wave]
I have one of the non-glare/compass/temperture rear-view mirrors. When I get into the X in the morning, the temp reads something like 98 Deg. F.
[Huh?] ; it does change up and down as i drive; then at night it goes to something like 96 deg.
now, I know we are having some heat right now out here, but come-on...
Where is the actual device that reads the temp? First I thought it was inside, but that made no sense; second I thought it might be on the opposite side of the mirror, but the window temp can vary, not giving you a true temp.
Anyone have a clue where this thing is? I was just wondering... and to see if someone has tried to move it somewhere else, to get a better reading of a dry temp.
Striker
"I've come to kick @ss and chew bubblegum, and im all out of gum..."
#59536 - 02/07/02 09:23 AM Re: Rear-View Mirror/temp Question.
BoarderPhreak Offline
Loc: Huntington, NY
In the front, near the grille...
If the truck has been sitting in the sun, or with a hot engine - the temperature might be inaccurate. After driving around a short spell though, it should be right on.
Perhaps the sensor fell from its location and is too close to something?
#59537 - 02/07/02 07:21 PM Re: Rear-View Mirror/temp Question.
troyboy Offline
Loc: nh
Funny, I was thinking about this today while sitting at the 7-11 waiting for the kids.
A/C on high, in park at an idle, it went up to 118deg.
Soon as I started moving it dropped to 96, which is about what the outside temp was.
in the morning i'll be sober, and you'll still be ugly.
#59538 - 02/07/02 09:57 PM Re: Rear-View Mirror/temp Question.
intron Offline
Loc: South Carolina
you can check out the installation instructions on www.xterraparts.com
basically it is on the same support bracket as the horn - in front of the grill. at least that is what it says, i haven't looked for mine yet but i have also thought about moving it. it said it was 138 here the other day while i was parked. like borderphreak said, once you drive around a bit, it stabilizes and gives a pretty accurate temp reading. there must be a better place to mount it though, a buddy of mine has a temp display in his minivan that doesn't vary nearly as much - maybe i will try to see where his is mounted. let us know if you do mount it, where, and what happened. good luck.
Instructions here
