Finally got the Piaa 510's installed on the X. These are the ones Xterraparts.com recommends if you don't have the pre-wired setup for the Nissan lights. Opinions here were that the Nissan lights suck anyway. Installation was a bit tricky as you have to drill mounting holes in the lower valance were the round cups get removed. Drilled directly in the center between the two slots for the cups. I also trimmed the upper portion of the interior of the hole so the lights could be aligned better up/down. The kit is first rate and the wiring harness was a perfect fit. These are a dull yellow moderatly bright but very useful for lighting the road just in front of you. And they look a hellva of alot better the those plastic cups Nissan stuck in there. I would rate the kit an 8 out of 10 for fit and looks.
Ekh.
[ 01-30-2002: Message edited by: ekh ]
The marksman hitteth his mark partly by pulling, partly by letting go.
