#647551 - 08/01/01 05:54 AM Power Socket Mod
xcanuk Offline
Loc: Mtl. Que. Canada
Tried to get the the relay and wires for the "always on" mod, took off all dash pieces concerned to get to it, but what it the trick to pull out the socket and the relay. Saw 2 clips on the side of the socket, couldn't pull it down. The relay is on a metal sleeve, but couldn't that off either. Any tricks or just more force needed ?
member of http://www.soxc.org
#647552 - 08/01/01 08:58 AM Re: Power Socket Mod
Lopaka Offline
Loc: Chinatown, Honolulu, Hawaii, ...
There is a locking tab on the plastic relay that prevents the relay from sliping off the metal tongue. Use a small screwdriver between the relay and metal tongue to release the locking tab. You can access all these parts by reaching under the dash without removing any part of the dash panel.
I started off with nothing and still have some left.
#647553 - 08/01/01 09:38 AM Re: Power Socket Mod
xcanuk Offline
Thanks, just couldn't see the locking tab. I tried to get to it without taking taking the lower dash trim off, but just couldn't get to it.
BTW.. does anyone know which fuse runs the aux plugs ?
[This message has been edited by xcanuk (edited January 08, 2001).]
#647554 - 09/01/01 04:19 AM Re: Power Socket Mod
ElectroKen Offline
Loc: Shelton, CT
The fuse for the aux sockets is in a relay/fuse box just aft of the battery.
