This past Sunday I got up early and changed my timing belt (with help).
I got my shipment from
xterraparts.com earlier in the week and here are the parts that I used..
Timing Belt Tensioner I was going to get the full boat that Xterraparts has
online but the bank was not going to allow too much more spending before they gave me a call. So I got the bare minimum. I had replaced my drive belts a few months ago so there was no need to do them again and everything else seemed to be in good working order.
Anyway.. We started about 10a.m. on Sunday and after a few trips to Autozone (for antifreeze and a puller for the harmonic balancer) and a trip to Lowes for a larger impact wrench (you need a 600ft/# wrench to get the bolt off of the crankshaft to remove the main pully) we were off and running.
A note about the belts condition.. The belt itself was in fair shape but the real issue was with the tensioner. It was not holding proper tension on the belt which could have caused the belt to fail due to increased stress.
Between lunch and the trips to the stores we were finished by 4 p.m. So overall the event took us about 5 hours start to finish.
Below are a few pictures of the adventure.
About to remove the radiator..
Radiator out and top cover of the belt is removed..
Here you can see the timing mark (11 o'clock)
Here is the old tensioner in place (but not holding much tension)
The old and the new
This could not have been done (or so I would like to think)without the shop manual. There is a lot of things that have to be removed to get to this belt and unless you have a decent amount of mechanical knowldge you SHOULD NOT try this at home.
NOTES:
The minimum parts that you should get for this job is the belt AND the tensioner.
If you have a lifted Xterra you will not have to jack the truck up to get to the bottom of the radiator.
If you have an ARB you will not have to remove the Fabritron skid plate to get to anything.. I do not know about the Calmini skid
I was able to get by with only removing the number one spark plug (the manual suggests removing all of them)
