1 registered (Tom),
46
#672797 - 23/08/10 03:31 PM
Installing functioning hood louvers
I found that after I got my new trailer that the engine would start to over heat a little while at highway speeds with the AC on. Seeing as I have a winch, lights etc on the front bumper I figured it was a flow issue. After some searching I finally found a place that sold functioning louvers not the crappy stick on fake ones. So far they seem to be doing their job. At idle while sitting still I can feel quite a bit of air moving out of them. Only time will tell if they solved my problem but I am thinking that they did. Here they are so you get an idea of the size. Since I was installing them on a carbon hood I used aluminum backing so that the rivets would not split it. First hole cut View from the underside with the one installed
#672809 - 24/08/10 10:11 AM
Re: Installing functioning hood louvers
[Re: XOC]
Loc: Northern Michigan
That is crazy, I was JUST looking into doing this a few days ago(cause I live out in the mojave) and here is this WITH pics! Did you have to take 2 fukitol before you started to cut to keep your hands steady?
#673022 - 11/09/10 02:20 PM
[Re: RNTKnives]
Edited by TJ (12/09/10 03:08 PM)
#673027 - 12/09/10 03:09 PM
[Re: skatchkins]
I Re-Hosted the pics...can you see them yet?
#673040 - 13/09/10 11:55 AM
[Re: XOC]
I see them now. They seem to be a bit close to each other. But aside from that they don't look bad.
Any finished pics?
Edit to add:
I now see why you placed them so close. Looking at the underhood shot I am guessing you did not want to cut through that brace. Yup...and that if the air was to flow over the engine, a central location was actually preferable, and more cross flow would then occur. Otherwise, your just air the bay out, which is of course fine, but less direct. If you figure the air is entering at the grill/engine fan area, this is really an exit point for peak heat build-up.
#679969 - 31/03/13 11:18 PM
[Re: TommieAnyan]
Banned
I'm a d bag spammer
Edited by TJ (08/05/13 02:10 PM)
#680401 - 14/08/13 05:01 AM
[Re: FYG]
Banned
I used the backing plates as a template to drill the holes for the rivet, and the juice of the 4 guys that pounded my anus to lubricate the drill bit. I did it all while I was spamming random sites because that's the only way I can get off.
