17/04/24 01:48 PM
0 registered (), 35 Guests and 0 Spiders online.
#674905 - 20/02/11 10:54 PM Resetting the SES / Check Engine Lamp
Jeff Belmont Offline
I figured I'd repost this here as it took me a while to find it - having just fixed a chewed up timing belt I needed to reset the Service Engine Soon (SES) / Check Engine Lamp (CEL) - fortunately NissanClub's "Dadster" Posted this - it might help a few of you out on here!
The original post is here:
http://www.nissanclub.com/forums/f-q-200...soon-light.html
It took a few tries to get it to work but after it did I was able to pull the codes and reset the lamp!
This is how you find out why your Service Engine Soon (SES) light is on and how to reset it. No tools required!
In car ECM Diagnostics/ECM Reset procedure:
1) Sit in the driver's seat.
2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
3) Fully depress and release the accelerator pedal five times in less than five seconds.
4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the SES light flashes.
5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)
The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
The ECM code repeats intself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.
You can look up the trouble codes in the ESM/FSM; there's a bunch of them. In the ESM, refer to page EC-639.
Additionally, if you get four blinks of ten (0000), the ECM is indicating no malfunction.
You can clear the code (and the annoying SES light) by holding down the accelerator pedal for more than 10 seconds while the SES light is blinking. When you release the pedal, the ECM erases the trouble code(s).
Works like a charm!
~Jeff
#675147 - 18/03/11 07:40 PM Re: Resetting the SES / Check Engine Lamp [Re: Jeff Belmont]
52 Offline
Good info. I used to just pull the neagtive off of the battery.
Check me out at: www.fishreapers.com
Mods: 2003 Granite NA 4X4, KN FIPK, PML, Poly Sway bushings, 32" BFG AT Ko
