ECXC20!
Yesterday at 09:33 AM
April 4th, 2020 at Gremlin Graveyard. MA
02/04/20 10:06 AM
by Paco Pico
30/03/20 01:03 PM
0 registered (), 19 Guests and 2 Spiders online.
#676065 - 17/07/11 06:27 PM Worn tire
roofgoat Offline
Loc: IL
I have some Cooper Discoverer ST's and they have about 50% life left, maybe a little less.
One tire has worn bad and needs to go. I hate to buy new tires with the other 3 that are fine.
If I buy the exact tire new for the bad one to replace, will it throw anything off and if not, where would it be best, front or back.
Edited by roofgoat (17/07/11 06:34 PM)
#676068 - 18/07/11 04:27 AM Re: Worn tire [Re: roofgoat]
Gonzo-2 Offline
Loc: Lansing, Michigan
If I'm not mistaken, and I may be, and we all know I'll be corrected if I am and that's a OK, but radials you replace in pairs. So if you have one that is excessively worn, find out why (alignment usually), fix the problem and replace both on that end of the truck (both fronts or both backs), cause it will throw wear/alignment off if you do just one.
That being said, if you replace two, do them on the front. The fronts wear faster due to more weight on the front (hence regular tire rotations) and you can afford to lose traction in the back better than the front.
Just my .02...
-G
'03SE
BFG AT/KO
Pre-crash post count - ~1100
