17/04/24 01:48 PM
0 registered (), 64 Guests and 0 Spiders online.
#677947 - 13/02/12 06:36 PM I need HELP with bad tire rub!
KS1 Offline
Loc: Houston, TX
I just did a 2" BL and a 2" SL, and went with 33x12.5's and I'm rubbing bad up front (only when turning, on the back side of the wheel well, the usual spot). I'm not sure what my next step is, but it's not really drivable the way it is. I'm pretty sure the basic melt mod isn't going to cut it. Any ideas???
Thanx
#677955 - 14/02/12 05:15 PM Re: I need HELP with bad tire rub! [Re: KS1]
Thanx
Lets start with these:
1. What year X do you have?
2. What is the back spacing on your rims?
3. Did you adjust the turn stop bolts?
4. Did you remove the plastic ledge at the rear of the front wells that the lower mud flap used to screw into?
Edited by TJ (14/02/12 05:16 PM)
