#678076 - 05/03/12 06:16 PM lift kits
Kristina Offline
what would be the most simple way to lift my 04 nissan xterra 2wd? I want to lift it about 3 inches?
#678085 - 06/03/12 09:52 AM Re: lift kits [Re: Kristina]
yellowbug Offline
Well for three inches on a 2we I would just do a body lift. Cheap and easy .
2" BL
1.5" PML
Front, Engine, Trans, & Transfer Skid Row Skids
DIY 3" Snorkel
33 Cooper Discover Stt
#678095 - 07/03/12 04:32 PM Re: lift kits [Re: Kristina]
WHY you want a lift is a key issue.
A Body Lift is cheap and easy...but really meant to make room for larger tires to retain uptravel/articulation, etc....
...so adding a 3" BL and leaving stock sized tires might look like a bit ...um ...wasted space in those wells.
If you're going off roading, a BL and larger tires WILL do a lot for you...as larger TIRES lift the entire rig, axles and all.
WHY do you want ~ 3" of lift?
#678097 - 07/03/12 04:43 PM Re: lift kits [Re: TJ]
Kristina Offline
I have 33 inch tires on the truck already, mostly for looks.
