1 registered (Tom),
67
#678339 - 13/04/12 02:23 PM
Front Sway Bar, end link bushings shot. your thoughts????
Loc: Ashland, PA U.S.A.
Ok, so last year right before the winter I started to hear some noise, but couldnt narrow it down. Today I found it. My questions are, should I replace with stock/factory, is there an easy after market to get that is worth using, ie: Advance Auto, Auto Zone, etc... I'm figuring its going to be easier , and better to replace bolts and bushings, cant see using the old bolts if I have to remove them anyway. The first image is with the wheels on the ground, the second is Jacked up, this is the drivers side, the Pass side isnt as bad, but is getting there.
#678343 - 14/04/12 08:57 PM
Re: Front Sway Bar, end link bushings shot. your thoughts????
[Re: e207]
Loc: Jackson, Wisconsin
2003 X......you can get the whole kit, comes with the bushings, washers, bolt and nut for about $6.00 per side from napa......took me all of 30 minutes to replace, what took the longest was getting the old ones out. One was already snapped and I had to cut the other side. Works fine for me and any Idiot can do it themselves,just make sure you stack the bushings and washers the right way. Hope this helps!
If your stupid today, it's a safe bet you'll be stupid tommorrow!
#678356 - 16/04/12 12:58 PM
[Re: granitex]
got them today at Napa, 12 bucks even for them. Tried the impact and a wrench before getting the grinder out, took them off pretty easy, I figured either they would come off, or maybe snap. Putting them on wasnt too bad, had to pry the pass side a bit to get the new stuff put in there, about a quarter inch. Made a noticable difference in driving, feels much better now. Thanks again guys for the replies. and yes, one of the washers and bushings was pushed down over the center sleeve, so it was still there, just hiding ! lol
Edited by e207 (16/04/12 01:02 PM)
#683045 - 01/06/17 09:16 PM
[Re: e207]
Has anyone replaced the bushings and end links with polyurethane? In the pas I thought I heard polyurethane squeaks and polygraphite doesnt. I dont even see any of these bushings in polygraphite. Thanks.
