by coolerman
22/01/18 10:49 AM
How many miles on you x
by coolerman
22/01/18 10:04 AM
Time To Replace Exhaust
by coolerman
22/01/18 09:49 AM
12/01/18 10:48 AM
1 registered (coolerman), 85 Guests and 2 Spiders online.
#679046 - 11/08/12 03:04 PM Where is the fuse for the rear aux power outlet
52 Offline
Where is the fuse that powers the rear cargo auxillary power outlet? Mine has stopped working and i use it as a power source for my reverse light relay.
Check me out at: www.fishreapers.com
Mods: 2003 Granite NA 4X4, KN FIPK, PML, Poly Sway bushings, 32" BFG AT Ko
#679047 - 11/08/12 03:59 PM Re: Where is the fuse for the rear aux power outlet [Re: 52]
52 Offline
It's only the outlet in the cargo area. The rest work fine. I tested the wires and they are no live. Is there a relay or other fuse I can check?
#679050 - 12/08/12 05:16 AM Re: Where is the fuse for the rear aux power outlet [Re: 52]
Nissan_MasterTech Offline
Loc: Florida
Have you looked at the fuse location and layout in the owners manual ?
#679289 - 10/10/12 08:00 PM Re: Where is the fuse for the rear aux power outlet [Re: 52]
lilstinz12 Offline
I believe it is located in the fuse panel that is under the hood. I also think its for two of the three outlets, at least that was the case for my 2001 se 4x4
#679613 - 10/01/13 02:54 PM Re: Where is the fuse for the rear aux power outlet [Re: lilstinz12]
intron Offline
Loc: South Carolina
Some of the power outlet fuses are in the in-cabin fuse box and some are under the hood. I was actually having trouble with this about a month ago as well. I checked the fuse and I replaced it even though it seemed to be fine (and I am pretty sure it was under the hood), but still no power. The power outlet behind my center console is also out. The one in the dash and the one inside of my center console are both working.
Not sure if the location of the fuses vary with different years though so you should double check for your particular year.
#679614 - 10/01/13 03:10 PM Re: Where is the fuse for the rear aux power outlet [Re: intron]
intron Offline
Loc: South Carolina
Jesus, just realized this post was from August - nevermind. lol.
