Yesterday at 04:27 PM
#679206 - 17/09/12 01:49 AM Keyless Entry Pad Options?
PsiFire Offline
I'm looking for a keyless entry option for my 2002 Xterra XE. I know the old 999KE-AR000MS is no longer available. I was wondering if anyone knew of another option for getting in without keys? I'd like something a little more secure than hiding a keyfob somewhere on the truck or installing a "dumb dumb" switch somewhere. Ideas?
2002 XE with Sport and Utility Package
Magnaflow Stainless Exhaust
Rancho RS5000 Shocks
#679350 - 25/10/12 05:21 AM Re: Keyless Entry Pad Options? [Re: PsiFire]
DeliriouX Offline
Loc: ontario canada
have an aftermarket keyless entry/alarm system installed
#679357 - 26/10/12 05:55 AM Re: Keyless Entry Pad Options? [Re: DeliriouX]
PsiFire Offline
I already have keyfobs. Someone needs to design a "fob" the mounts to the outside of the vehicle, is code activated, and trips the door unlocks. It can't be that hard.
#679469 - 18/11/12 07:13 AM Re: Keyless Entry Pad Options? [Re: PsiFire]
DeliriouX Offline
Loc: ontario canada
my shop had a request the other day....yep you guessed it...a wired universal keyless keypad type entry system. i researched it for her and found them here>>>www.keyless.com
#679472 - 18/11/12 11:00 PM Re: Keyless Entry Pad Options? [Re: DeliriouX]
PsiFire Offline
Wow. Interesting. Was hoping for a true wireless option, but this might be the next best thing. Their KE-1700 looks just like the keypad that Nissan used to offer.
#679562 - 22/12/12 04:30 PM Re: Keyless Entry Pad Options? [Re: PsiFire]
DeliriouX Offline
Loc: ontario canada
i thought ford was the only ones with the factory keypad. i installed that piece for the customer, very easy and straight forward. you can get access to the wire code tech sheet here>>>
http://s242.photobucket.com/albums/ff279/DISTORTED_WUN/my%20X%20mods%20thread/
i have them posted there for the various X`s gen 1, 1.5, and 2, should be an easy DIY if you r handy with wiring.
#680039 - 28/04/13 11:26 AM Re: Keyless Entry Pad Options? [Re: PsiFire]
Kiter Offline
When my Nissan Key Pad, failed and I discovered that Nissan does not carry them anymore, I was very dismayed. I NEED a keypad entry. I spend a lot of time in the ocean and keeping a key on my person is not realistic.
I purchased an aftermarket (Accele RS505) product and installed it so it mimics the driver side door lock/unlock switch. This all works fine. Unfortunately, the "Vehicle Security System" doesn't like it and goes off when the door is openned. After finding that the VSS is documented in the "Body" chapter of the ESM rather than "Electrical", I find that the VSS is disarmed by the turn of a key. The wiring diagram shows that being a ground signal on pin 7 at the BCM (Body Control Module). (The lock/unlock signal to BCM for the switch are also gounds.) Unfortunately, grounding this pin does not work. Does anyone know how the door cylinder switch really signals the BCM to disable the security system?
For now I have lock the keys in a reasonably accessible in the Xterra so I can get them quickly to stop the alarm.
#680222 - 02/07/13 11:22 PM Re: Keyless Entry Pad Options? [Re: Kiter]
camron Offline
i have an key less aftermarket alarm system but most of the time the light blink after i locked the door or the ignition system and other electrical component go off due to alarm when the door are not locked properly with the fob.
Be Secure, Be Safe
