80
#680660 - 01/11/13 03:30 AM
help me please!!!
After replacing my fan belt, a/c compressor and thermostat my truck is still running hot. Can anyone help me fiqure out what's wrong?
#680662 - 01/11/13 07:14 AM
Re: help me please!!!
[Re: xdriver]
Loc: Greensboro, NC
Might have a clog in the radiator or coolant hose. Have you done a coolant flush recently?
#680663 - 01/11/13 07:33 AM
[Re: xdriver]
After replacing my fan belt, a/c compressor and thermostat my truck is still running hot. Can anyone help me fiqure out what's wrong? If the radiator cap is not sealing well, it will run hot. Are you basing this on the dash gauge saying its hot? If so, cross check it with an OBD reading, as the sensor used for the dash reading is less reliable, and the one for the OBD Port and ECU is more reliable (I've seen people go NUTZ putting vents in their hoods, swapping out radiators and everything, and it was just a bad sensor on the dash gauge lying to them - It wasn't even hot)
#680675 - 06/11/13 11:08 AM
[Re: TJ]
Loc: Mount Laurel, NJ
I agree w/TJ, but check to make sure there's no mud or leaves (esp. this time of year) blocking the airflow through the radiator. this stuff gets trapped between the A/C condenser & the radiator.
To check the sensor, I use an infrared thermometer & obdII scanner. compare the readings, cold & at operating temp. they should be close.
Brad
#680677 - 07/11/13 01:55 PM
[Re: Xwrench]
Brad I was assuming that it was only after doing the fan belt, etc...so the same leaves would be present before too...and not be a cause. Always good to check though....between leaves and adobe, there's always SOMETHING baking in my fins.
