ECXC20!
Yesterday at 09:33 AM
April 4th, 2020 at Gremlin Graveyard. MA
02/04/20 10:06 AM
by Paco Pico
30/03/20 01:03 PM
0 registered (), 19 Guests and 2 Spiders online.
#680849 - 18/01/14 10:28 PM Tire size vs speed?
sdterra Offline
I have a 2012 XTerra X and want to change tires from the stock 265 70 16's to 265 75 16's from a Pro 4X (which are taller). How can I get my speedometer and odometer to read accurately with the new tires? Is there a gear in the gauge cluster or the trans that I can change?
#680852 - 19/01/14 08:57 PM Re: Tire size vs speed? [Re: sdterra]
The dealer can do that for you with the computer they use to set parameters...as you want a stock size tire.
I believe the dealer's set-up can go up to a 285/75/16, which is a bit larger than stock, and, the size most guys upgrade to if they are bothering to upsize.
#680858 - 20/01/14 11:29 PM Re: Tire size vs speed? [Re: TJ]
sdterra Offline
Thanks TJ, I really appreciate the reply. Some of the guys over on thenewx.org were saying that the trucks are normally calibrated for the Pro 4X tires (265 75's), and are actually a couple MPH off with the 265 70's (and other sizes). Good to know there is some wiggle room with programming though, for the next time I'm tire shopping.
