17/04/24 01:48 PM
0 registered (), 35 Guests and 0 Spiders online.
#682680 - 28/10/14 01:17 PM Can I squeeze 295's on with RadFlo's?
Jedon Offline
I have RadFlo 2's and AAL.
I want BFG TA KO's in load range D not E and they aren't available in 285/75/16 D
They are in 295/75/16 though and that seems like only a tiny bit bigger but from searching round on here it's iffy without cutting the fenders.
I've done the melt mod.
I need to order from TireRack today in order to get them installed before snow storm!
Thanks!!
#682689 - 19/11/14 06:20 AM Re: Can I squeeze 295's on with RadFlo's? [Re: Jedon]
You do realize that a 295/75/16 is only 0.2" larger than the 285/75/16, so it only sticks out another 0.1"? (Its also only going to stick out to the sides by a measly extra 5 millimeters...)
You could also do 305/70/16...33" diameter but a larger foot print.
PS - Using shocks with built-in bumpstop extensions (Prevent uptravel/compression to raise your ride height) is evil and immoral, and robs you of precious wheel travel....and area bad idea.
Edited by TJ (19/11/14 06:24 AM)
