12/01/18 10:48 AM
0 registered (), 85 Guests and 2 Spiders online.
#683058 - 08/12/17 10:26 PM 2002 Side marker #168 bulb not working yet I have power..
sierra77 Offline
I have a 2002 with a drivers side, side marker light out.
It takes a #168 bulb. Tried 2 bulbs that DO light when directly jumped from battery using test leads.
I have voltage tested the bulb socket at 11.4 Volts.
But the two known good bulbs will not light when inserting, twisting, jiggling, tapping. Contacts look fine, no corrosion.
Gasket is good.
What gives?
#683059 - 10/12/17 06:18 PM Re: 2002 Side marker #168 bulb not working yet I have power.. [Re: sierra77]
sierra77 Offline
In better light I saw the connected pigtail from the fog light assy had one strand of wire hanging on for dear life.
The factory installation has too much stress on wires where they enter the connector so time and vibration did it.
Dealer wanted $60+ for entire pigtail assy.
I passed on that and Pulled two connectors from the junk yard for two dollars. Replaced in 15 minutes.
Edited by sierra77 (10/12/17 07:37 PM)
