Page 3 of 3 < 1 2 3
#678539 - 13/05/12 11:03 PM Re: How many miles on you x [Re: slantyshanty]
Gator Saver Offline
Loc: Lakeland, FL
93,350 today Bought it with 36 miles on it in 2000. We use her Highlander Hybrid for everything now.. 24mpg.. beats my 12mpg
Real Men Wear Kilts
Member number #112 Aug. 20, 2000
#678588 - 20/05/12 08:01 PM Re: How many miles on you x [Re: Mobycat]
Fang Offline
Loc: Wa.St. Seattle,King
How may clutches have you gone through in 156,000 mi.? Been reading about tons of clutch failures on 2nd gen. Manual Off roads. I have a 2006 with
38,000 mi.
Edited by Fang (20/05/12 08:50 PM)
Edit Reason: put 38 not 38,000mi.
Fang. Have no idea of what a UBBCode is. This site had to have been set up by a person under 50. Don't get it.
#678675 - 06/06/12 09:40 AM Re: How many miles on you x [Re: Gonzo-2]
Cliff Offline
Loc: Idaho, U.S.A
I bought my 06 off road in April 2006. I worked out of town for until 2008 so it didn't get much mileage on it. I now have 43500 since I am now retired and drive it a lot more. Noticed that the fuel economy, If you can call it that in an Xterra, has gone down lately. I am going to run some injector cleaner through it this week and see if that helps.
#678677 - 06/06/12 12:38 PM Re: How many miles on you x [Re: Tradhunter]
Happy Birthday Kayaker Offline
Loc: Ontario
2002 SC
73000
Yup!
#678685 - 06/06/12 07:23 PM Re: How many miles on you x [Re: Cliff]
Your plugs might be getting a bit long in the tooth, and, MAF cleaner might be a good idea too.
Its also possible that you need to change some lubes other than engine oil, like in the diffs, etc.
Going full synthetic saved me a ton o $
#678688 - 07/06/12 05:17 PM Re: How many miles on you x [Re: TJ]
Cliff Offline
Loc: Idaho, U.S.A
I have had the differential fluids changed with synthetic fluids. I always have changed my oil using synthetic oil. At this point I am not sure what other fluids I need to change.
#678697 - 08/06/12 04:34 PM Re: How many miles on you x [Re: Cliff]
Weak04XE Offline
Loc: Wamego ks
2004 XE. 114000 head went at 93000. Still needs tranny flush and fresh front and rear gear
Edited by Weak04XE (08/06/12 04:35 PM)
3.3 to push 5200lbs.? Well it kinda works just wish I had 6 speed
#678891 - 10/07/12 09:44 AM Re: How many miles on you x [Re: baf6]
Nighthawk Offline
Loc: Riverdale, New York, USA
My 04 X had around 59K when I traded it in yesterday.
Currently 2012 Pro-4 Xterra Night Armor
Prior owned 2004 XE Xterra Silver
#678895 - 11/07/12 04:47 AM Re: How many miles on you x [Re: Nighthawk]
Gonzo-2 Offline
Loc: Lansing, Michigan
When I got gas yesterday, my '03 still only has 54,500! (I live 3 miles from work!).
'03SE
BFG AT/KO
Pre-crash post count - ~1100
#678905 - 12/07/12 12:06 AM Re: How many miles on you x [Re: Gonzo-2]
NY Madman Offline
Loc: Florida
My 2001 Xterra XE has only 36,000 miles on it.
I've always had two vehicles since I've owned the X. I obviously don't use it every day, or for long drives.
In fact, I had to buy new tires a couple of years ago not because the original tires were worn ... but because they were dry rotting.
#679221 - 19/09/12 12:15 PM Re: How many miles on you x [Re: baf6]
17A Offline
I have a 2012. Just picked up last week.....900km's.
Dave
2012 Xterra S
#679223 - 19/09/12 04:29 PM Re: How many miles on you x [Re: 17A]
PsiFire Offline
2002 XE with about 133k miles on it. Only broke down on me twice:
Starter failed while on vacation last year at about 120k.
Brake line rusted through and pissed brake fluid on the manifold causing a "small fire" earlier this year.
2002 XE with Sport and Utility Package
Magnaflow Stainless Exhaust
Rancho RS5000 Shocks
#679231 - 21/09/12 01:32 PM Re: How many miles on you x [Re: PsiFire]
turboprop Offline
Loc: Idaho
My 2012 S has 1110 miles on it which is a replacement for my 1990 Suzuki Samurai which was wrecked in June
8^(
#679312 - 19/10/12 08:18 AM Re: How many miles on you x [Re: turboprop]
coolerman Offline
Loc: Paint Lick, KY USA
May 1999 Xterra XE Automatic 181,xxx miles. Just replaced a starter (original)last month. Other than normal maintenance and valve cover gaskets, no major failures. I do have a hole in the passenger side rocker panel from a meeting with a rock years ago and a couple of bubbles of rust on the passenger side rear wheelwell and one on the hatch. Just drove it 3100 miles to Moab to camp and wheel for a week. It always has been under powered in my opinion but this time across Vail Pass on Route 70 was 40 mph... and I was not even towing my camper. Looking at one of the new Pro models...
Coolerman
Past Member of MAXC/TLCA
2000 V6 Auto SE Xterra
2013 Altima SV
1971 Toyota Land Cruiser
#679356 - 25/10/12 01:21 PM Re: How many miles on you x [Re: coolerman]
Buckshot Offline
Loc: Georgia
114,700. Currently on my:
Second timing belt,
Second set of shocks & brakes,
And third set of tires.
I went from single in college to married & two kids under the same rack.
I'll update XOC again when I'm on my third timing belt.
Cheers
"Everybody to the limit, the Cheat is to the limit, everybody come on Fhqwhgads!"
#682971 - 31/03/16 07:47 PM Re: How many miles on you x [Re: Buckshot]
DocNo Offline
Loc: NoVA
Just over 90K and still going strong - no intention of getting rid of her any time soon!
Murderous Fire!
#682980 - 09/04/16 06:34 AM Re: How many miles on you x [Re: DocNo]
Oharag Offline
2005 190k 6 sod. Clutch is still perfect. In fact just test drove a 2015 and it felt mushy. My timing chain needs replacement. Rear seals always fail on my axel. Replaced numerous times. Looking to trade it out for a 2015 Xterra. Love the vehicle.
#682982 - 10/04/16 03:17 PM Re: How many miles on you x [Re: Oharag]
Tennesseewarrior Offline
Year 2000. Just turned 92k
#682998 - 22/08/16 06:47 AM Re: How many miles on you x [Re: baf6]
Randy Howerton Offline
'03' with 150K. Brand new (to me) runs great, but a small oil leak that fouls the starter motor. The mechanic says he fixed the oil leak, but there are still a few tiny spots on the cement. I like this car a lot, but the stereo is for modern younger technologist, not old men. But I'm figuring it out.
#683028 - 05/03/17 03:22 PM Re: How many miles on you x [Re: Randy Howerton]
Canope Offline
Loc: Pennsylvania
51000 on my 2004. I was an original or so member here. I wonder who is still here.
Thomas
"A great civilization is not conquered from without until it has destroyed itself from within."
#683030 - 07/03/17 02:18 PM Re: How many miles on you x [Re: Canope]
Oceancitysurf77 Offline
2003 X here bought with 74K on it in '06. Went to 196,000 (over 10 years) before it was rear ended by a tractor trailer at 20mph and totaled. Had just put fresh tires on it at 195,850!! I'm sure it would have gone the distance. RIP ONYX
#683063 - 22/01/18 10:04 AM Re: How many miles on you x [Re: Oceancitysurf77]
coolerman Offline
Update: Now at 208,563 and have several issue to fix as it sat for about a year after getting the 2012 Pro-4X.
Exhaust and brake work is in my future!
Coolerman
2013 Altima SV
#683120 - 28/09/19 12:31 PM Re: How many miles on you x [Re: Tradhunter]
sirscroddy Offline
234,000 on the 2004. Still humming.
#683121 - 27/10/19 02:28 PM Re: How many miles on you x [Re: sirscroddy]
DocNo Offline
Loc: NoVA
Just recently turned over 100K! Rear brake line to the rear drivers side brake got a leak - will be replacing today. Otherwise the truck just keeps chugging along!
Edited by DocNo (27/10/19 02:29 PM)
Murderous Fire!
#683123 - 03/11/19 02:25 PM Re: How many miles on you x [Re: Nail Bender]
Gold Rush Offline
Loc: Franklin, NH
2011 Pro-4x with 105,000 miles.
You can't tell which way the train went by the tracks it left behind.
Page 3 of 3 < 1 2 3
