Been searching for a little info on this to no avail. Any information or a point in the right direction to investigate would be greatly appreciated.
My 2000 X SE's rear window wiper will not "wash" with washer fluid when the switch is depressed. The wiper works correctly other then that. The switch will turn it on and off. I can't remember offhand if there is a sound made when the button is depressed to wash, but if that is important I can go check for confirmation.
I was wondering what some of the potential causes could be. I didn't think a fuse could be the problem since other then "washing" the wiper works. I wasn't sure if there was a seperate reservoir for it.
I was checking the Haynes book and saw mention of replacing the motor and amplifier but was unsure if either could be the source of the problem. I was unsure if the motor had anything to do with the pumping of the fluid and I have no clue what the amplifier does other then some type of amplification.
All my searches turned up empty or with dead threads
Thanks!
Noobie001
