I'm not clear as to the type of light you want. Fog or driving or both. For twisty, narrow trails a powerful fog mounted at bumper height would help. For more open roads, a light with driving beam would be usefull.
Some of the better brands include PIAA, Catz, IPF and Hella. The model that looks on your X is a matter of your preference. Usually the kits come with a full wiring harness including fuse, relay, switch and indicator light. You can set up the circuit so the lights will come on whenever you choose. For example, I replaced the OEM fogs and have them set so they can be used whenever the parking lights or hi/low beams are on. OTOH, the IPF 960 driving lights can only be selected if the hi beams are on. Just depends where you connect the relay's signal wire.
dave and Xtoy - turn night into day
