ccspelman,
According to the owner's manual for my 2001 XTerra, the severe service schedule at 45k calls for:
1.oil change
2.inspect brake lines, pads, shoes, rotors, drums
3.inspect ATF fluid or manual tranny oil
4.inspect LSD fluid (if so equipped)
5.inspect steering linkage,axle and suspension
6.inspect driveshaft boots
7.lubricate front prop shaft
8.inspect front wheel bearing grease and hub grease if so equipped
9.inspect exhaust system
Now, to me 278 dollars is a pantload of money to inspect this sort of stuff that, IMO, you should keep an eye on anyway. If they were going to change out the tranny and diff fluids for that price, I'd consider it...but since it's really just an inspection plus an oil change and front prop shaft lube (ha, if the stealership even does all of this stuff) I'd do it all myself and save the money.
Bogatyr
2001 Nissan XTerra XE 40k
1984 Honda CRX 1.5 83k
1970 Land Rover IIa 88" 41k
1966 Land Rover IIa 109" 35k
