What kind of off roading interests you?
For example, there's trail riding, mostly dirt/gravel or sand, etc...mudding, mostly, well, mud and water, etc...and rock crawling...mostly, uh, rocks.
The reason I ask is that you can mod a bit differntly for each scenario, and put your money to best use.
Rockcrawling is a slow technical process where you need to be able to think about several things at once to avoid rolling over, smashing something, breaking parts, etc...but a lot of fun if you ease into it...then its a slow motion roller coaster. You need armor, and clearance, and hard to puncture tires. Lockers and a winch, etc, help.
Mudding requires lots of traction, big tread lugs, and power to churn them....a snorkle to breath when you submerge helps, as do washable upholstery, etc.
Trail riding can require any combination, as its what ever you encounter, a puddle, a river, a fallen log, a broken down jeep, etc....but is typically more tame versions of what a crawler or mudder might attempt.
TN has wooded, muddy areas, so mud or trail would be easy to find...rocks are also around (Mtns).
So - What interests you?
You ready to go hard core and cut sheet metal, or are you looking to keep stock appearance?
Another considerations - Do you drive to work or school everyday...so you need mods that will work ON road too?
Do you have an idea as to how much on or off road cabability you would sacrifice to maximize the other?
