Originally posted by boognight:
I just go to the local car wash place, rent a power washer and search for mudd anywhere in the under carriage... usually where you see a little... there is a lot more hidden. if you look under the skid plates there is a lot of mudd... make sure you clear it away from moving parts.. you dont want sand a grit getting into barrings.
if you are going to wash the motor, make sure its cold and everything is off. and be somewhere where you can leave it off for a while.
someone already has suggested... get a sprinkler, one of those ones that sway back and forth... and just leave it under your X while moving it around about every twenty minutes... after about an hour most of the mudd should be removed.
I'm sure that would work but the thought of it cracks me up.
I can see my fiance asking me, "Are you watering the truck?"
