1 registered (Tom),
46
#98163 - 21/03/01 09:01 AM
4WD Noise
Loc: Rochester NY
I have had my X for about 3 weeks.
When I switch into 4WD high with the hubs unlocked while moving (under 25 mph of course) I hear a bang or thud. I don't hear the noise when the Hubs are locked and I switch to 4WD.
Is this normal? Any suggestions?
------------------ -- 2001 XE 4WD Sp, Pw, Ut Silver Ice
2001 XE 4WD 3pack Auto with a tow hitch Silver Ice
#98164 - 21/03/01 09:09 AM
Re: 4WD Noise
Loc: San Antonio, TX
yes this is normal, its the front hubs locking. mine does this too. i would recommend slowing down before switching into 4wd even though nissan says up to 25mph. i try to come to a complete stop for 4 hi also.
------------------ Silver Ice Xterra Xe 4x4 auto 3pk
#98165 - 21/03/01 09:11 AM
Re: 4WD Noise
i think its pretty common among X's to have that noise...personally, i hear it if i'm going 5, 10 or 25 mph, but once the hubs are locked, its smooth as silk...
------------------ Just Blue XE 4x4 3pack w/ many extras and newly added XOC sticker!!!
#98167 - 21/03/01 09:19 AM
Re: 4WD Noise
Loc: Rochester NY
wow .. I got questions .. you got answers.. Thanks for the quick responses.
Yeah .. i've been trying to switch at speeds lower then 25 (5-20) if not stopping completely.
#98168 - 21/03/01 09:20 AM
Re: 4WD Noise
Loc: San Diego, CA
Originally posted by Ag_xterra: yes this is normal, its the front hubs locking. mine does this too. i would recommend slowing down before switching into 4wd even though nissan says up to 25mph. i try to come to a complete stop for 4 hi also.
The thud isn't the hubs locking, it's because the drivetrain components aren't spinning when the transfer case engages. The already spinning tranfser case engages a non spinning drivetrain. When the hubs are locked it doesn't do it because the locked hubs keep the drivetrain spinning at the same speed as the transfer case so engagement is nice and smooth. ------------------ Eric Konarske & Lara, my X '01 Solar Yellow XE 3 Pk. 4x4
#98169 - 21/03/01 09:35 AM
Re: 4WD Noise
Loc: Rochester NY
Originally posted by ILUVMYX: The thud isn't the hubs locking, it's because the drivetrain components aren't spinning when the transfer case engages. The already spinning tranfser case engages a non spinning drivetrain. When the hubs are locked it doesn't do it because the locked hubs keep the drivetrain spinning at the same speed as the transfer case so engagement is nice and smooth.
bottom line .. is this normal? Will it hurt my brand new X??? ------------------ 2001 XE 4WD 3pack Auto with a tow hitch Silver Ice
#98170 - 21/03/01 09:37 AM
Re: 4WD Noise
Loc: Brunswick, GA
You should hear and feel the bang when you're going 40 mph! When I first test drove an Xterra the salesman told me I could switch on the fly. He told me that I could be going 45 and switch. I knew this was incorrect, but I figured what the hell (I wasn't buying that X anyway). He told me to switch to neutral (auto tranny), throw it in 4Hi and then back to drive. When I switched back to drive the bang was real strong and I felt the truck shudder. He told me it was probably because the truck had never been in 4WD before. I knew what the real reason was -Michael ------------------ Michael GirardoMember - MAXC | Moderator - XOC www.avaloninternet.net/users/bythebay/xterra <---Redesigned
#98171 - 21/03/01 09:41 AM
Re: 4WD Noise
Loc: Rochester NY
Originally posted by swampwrecker: You should hear and feel the bang when you're going 40 mph! When I first test drove an Xterra the salesman told me I could switch on the fly. He told me that I could be going 45 and switch. I knew this was incorrect, but I figured what the hell (I wasn't buying that X anyway). He told me to switch to neutral (auto tranny), throw it in 4Hi and then back to drive. When I switched back to drive the bang was real strong and I felt the truck shudder. He told me it was probably because the truck had never been in 4WD before. I knew what the real reason was
-Michael
Funny story... Did you leave the tranny on the road ------------------ 2001 XE 4WD 3pack Auto with a tow hitch Silver Ice
#98172 - 21/03/01 09:54 AM
Re: 4WD Noise
Loc: San Diego, CA
Yes, it is normal. Like everyone else said, I personally wouln't do it even at the 25 MPH limit Nissan set. At 25 it hits pretty hard. That's one of the nice things about manual locking hubs. Once you know the hubs are locked, you don't need to worry about your speed when you go into 4wd. ------------------ Eric Konarske & Lara, my X '01 Solar Yellow XE 3 Pk. 4x4
#98173 - 21/03/01 08:01 PM
Re: 4WD Noise
Loc: High Point, NC
Hmm, mine barely makes a noise when switching to 4wd. Only way you can hear anything is if you have the air off, radio off and everything about perfectly quiet. Maybe I'm just lucky for a change! Travis ------------------ '00 4x4 V6 XE Yella 3pack
'00 4x4 V6 XE
#98174 - 21/03/01 08:09 PM
Re: 4WD Noise
Loc: San Diego, CA
Originally posted by Lightning: Hmm, mine barely makes a noise when switching to 4wd. Only way you can hear anything is if you have the air off, radio off and everything about perfectly quiet. Maybe I'm just lucky for a change!
Travis
Are you moving while switching to 4wd? If you are moving at 15 mph or better and it still makes no noise while switching, your hubs must be locked. If your hubs won't unlock, I'd have that looked at. Maybe you aren't so lucky after all ------------------ Eric Konarske & Lara, my X '01 Solar Yellow XE 3 Pk. 4x4
