Hey guys.
I have the rest of my truck setup finally;
3" SLR suspension Lift, SLR steering system, Lockers, Calmini T-case gears, Full armour, sliders, ARB, KMA, etc...
I'll be ordering a Body lift soon and I was wondering which one I should get.
I know that the 2" lift is much easier of an install. But more trimming is involved to get the 35" (or 36") tires to fit "properly". But a lower Center of Gravity with the 2" BL as a result.
The 3" is more money, takes longer to install, but will clear larger tires easier with less trimming.
I dont mind getting the sawzall or angle grinder out to get the tires to fit without rubbing.
If I go with the 35's, they will be on my 16"x8" rims with a 5" Backspacing..
If I go with the 36's they will be on my Pathy 6 spoke rims, 15"x7".
A cradle or something will be built to relocate my ARB. And larger brackets will be used for the rear tire carrier relocation.
Sliders will probably stay where they are, I might actually use them as a step. Or I'll switch sides and install them upside down to compensate a bit.
EOE sliders are capable of doing that as I read on this board.
I will also (hopefully) be getting a partial exo installed when the front bumper gets relocated. I'm just getting the bars that will connect ARB to the sliders, and the rear bumper to the sliders for now..
All of those with Body Lifts please share your opinion, Tire size and 2" or 3" BL?
Do I have to do anything with my Skid row skidplates to get them to fit properly?
Any info would be greatly appreciated.
Thanks all!
